VULKOLLAN® press-on-band drive wheel load capacity 5,400kg/11,900lbs |
RAEDER-VOGEL
® is the renowned specialist manufacturer of premium quality wheels, press-on tires, and castors for all demanding and heavy-duty applications. OEM manufacturers around the world rely on our wheels and castors for their standard and custom-built heavy forklifts.
We manufacture proven standard and tailor-made wheels and castors for a wide range of applications: for glass transporters where the weight of the forklift alone can exceed 30 tons as well as for the steel and aluminium industry, especially for coil transports with coil forklifts or trolleys. Other industries served include the automotive, timber, cable, aviation, paper and print, textile, wind and solar energy sector as well as die handling, foundries and builder's merchants.
HUBTEX model GKS 150 with VULKOLLAN® press-on tyres load capacity 10,000kg/22,050lbs |
Our range of premium quality wheels and castors for heavy forklifts includes load and drive wheels with VULKOLLAN
®, PEVOPUR
®, PEVODYN
®, PEVODYN
®-SOFT, or solid rubber tread.
We recommend the high-performance elastomer VULKOLLAN
® (in 93° or 95° Shore A shore hardness) for applications with great demands on speed, damping, load capacity, and durability.
PEVODYN
® (93° Shore A) is a new high-performance polymer developed by us. It is recommended for high speed and heavy load applications, too. The essential advantages of this material are its low starting and rolling resistance which significantly reduce energy consumption.
PEVOPUR
® (93° Shore A) is high-quality hot cast and heat treated
MORA model M 250 CS with PEVOPUR® press-on tyres load capacity 17,000kg/37,500lbs and 10,500kg/23,150lbs respectively |
polyurethane elastomer for applications with a lower requirement profile (for maximum speeds up to 8 km/h/5 mph).
As an alternative to solid rubber with a significantly longer service life and much higher load capacities we have developed PEVODYN
®-SOFT
(78° Shore A). Wheels with PEVODYN
®-SOFT tread offer better ride comfort combined with better shock and noise absorption, thus protecting sensitive floors and fragile transport goods.
All wheels are either designed with a welded wheel centre
and direct bonded tread or as press-on band versions. For side loaders and four-way trucks we also offer chain driven castors without offset.
HUBTEX glass transporter model GTR 330/E with VULKOLLAN® press-on band wheels load capacity 14,500kg/32,000lbs |
With a range of more than 20 high-quality wheel materials, we are able to offer solutions for specialised applications with tough requirements, such as improved traction or electrical charges and discharges to our customers.
Our specialist sales and technical staff are looking forward to cooperating with you in developing the optimum solution for your heavy forklifts. Please visit
www.raedervogel.de or our
shopfront for more company or product information.
About RAEDER-VOGEL®Chain-driven swivel castor with twin VULKOLLAN® wheels load capacity 7,300kg/16,100lbs |
RAEDER-VOGEL
® is one of the leading manufacturers worldwide for wheels and castors made of VULKOLLAN
® and polyurethane with modern production facilities in Germany. With more than 60 years of experience, the renowned manufacturer specialises in forklift and materials handling parts such as drive wheels, press-on tyres, guiding wheels, load wheels, running wheels, pallet rollers, wheels for wheel hub drives, stabilising wheels, stabilising castors, as well as custom wheels. RAEDER-VOGEL
® supplies major forklift, electrical drive and materials handling OEM in Europe, North and South America, as well as in Asia.
Moreover, the German manufacturer's extensive product range includes industrial castors (also in stainless steel), electrically conductive wheels and castors, heavy-duty wheels and castors, as well as custom wheels and castors for mechanical and plant engineering and construction up to 20 t load capacity.
Chain-driven castor with six solid rubber wheels load capacity3,165kg/6,980lbs |
RAEDER-VOGEL®
RAEDER- UND ROLLLENFABRIK
GMBH & CO. KGSperlsdeicher Weg 19 - 23
21109 Hamburg
Germany
Phone: +49 40 75499-0
Fax: +49 40 75499-198
Email:
rv@raedervogel.de
Click here to view www.raedervogel.de.
Click here to view the RAEDER-VOGEL® Shopfront.
