Increase your profitability with MH Equipment's Fleet Management Software
- 4 Apr 2013 ( #610 )
Some companies who manage a material handling fleet of forklifts, lift trucks or other equipment consider it a distraction from other aspects of running a business. Furthermore, for some distribution companies fleet management consumes the most time and costly expenditure after payroll.
At MH Equipment, we analyze your forklift or lift truck fleet and recommend the best way to lower your overall costs. This includes keeping your fleet up to date with the latest, most efficient material handling equipment, protecting you against the hidden costs of using older equipment resulting in excess maintenance expenses, down time dollar spending, and reduced productivity; and then consistently monitoring and maintaining that equipment for maximum efficiency. Our fleet management services and warehousing solutions have helped increase profitability for material handling operations.
Utilizing our 5-step Fleet Management Process, MH Equipment will conduct a comprehensive fleet analysis in order to identify areas to improve efficiency and productivity including offering suggestions to properly size, configure, maintain, and manage your material handling equipment fleet. Through a schedule of maintenance and timely fleet replacement, you'll have a material handling fleet you need to meet evolving business needs.
click for larger view
Features
Asset Management
MH Fleet can help organizations get the most value from their capital investments in equipment by increasing productivity and providing visibility into equipment use. Using material handling equipment efficiently helps make companies aware of how often and how long each piece of equipment is utilized. Over time, asset utilization data can help you determine the need for additional or fewer assets.
Preventive Maintenance
MH Fleet can help you maximize your resources, reduce downtime and increase overall equipment efficiency. Our easy-to-use, intuitive fleet optimization tool helps identify potential issues within your fleet in order to prevent future equipment failure. MH Fleet documents activities making it easier to analyze trends and spot recurrent problems which impact your production and profits!
Scheduling
Let MH Fleet monitor your equipment maintenance by odometer, hours, days, or calendar dates. The MH Fleet management solution monitors all material handling equipment, from forklifts to AWP's - anything that needs routine maintenance - and lets you decide your maintenance schedule for best performance.
Repair Histories
Produce complete repair histories for each vehicle, including parts and labor with MH Fleet. Review your repair costs to spot recurrent problems and potential replacement opportunities.
Equipment Utilization Tracking
See which employees are using which pieces of equipment in order to address positive and negative usage. Eliminate unauthorized equipment use as well as increase employee accountability.
Role-Based Hierarchy
Depending on your role within the company, MH Fleet offers customized views using a single, common data repository. MH Fleet data can be grouped by up to four levels of hierarchy depending on your business needs.
For more information on MH Fleet software, or to view our video
Visit www.mhfleet.com/software
MH Fleet Corporate Headquarters
Chillicothe, IL
Email send a message
Website www.mhfleet.com
Toll Free (877) 884.8465
Phone (309) 579.8020
Fax (309) 579.2510
For more information about MH Fleet's services click here.
Briefs United States
