RUYI launches New Single Column Walkie Stacker – CDDRD12
- 27 Jun 2013 ( #622 )
Click image to enlarge
The RUYI CDDRD Single Column Walkie Stacker with 1,200 kg capacity, wide-view mast and low service weight is designed for use in airports, supermarkets, small warehouses and logistics centres. It is suitable for indoor and outdoor use and short-distance operation. Particularly applicable to work on low-force-withstanding floors, environmentally friendly for transport.
Advantages:
Safety and productivity:
  • AC motor with high transmission efficiency, without the need to replace carbon brushes, provides good ramp starting performance.
  • Low center of gravity for good stability and smooth running.
  • Small minimum turning radius and excellent steering operating performance.
  • Using the most advanced technology of AC variable speed makes the motor more reliable and maintenance-free.
  • Accurate control of both the walking speed and the lifting speed.
  • Shock device greatly reduces noise.
  • Sideway moving battery makes for easy replacement and maintenance.
  • The multi-function display instrument shows BDI, fault code, working time and speed.
  • Using the built-in charger makes it easy to disassemble according to customer requirements.
  • Adopting integrated electrical system, the line is clean and aesthetic, with easy assembly and maintanance.
  • Using environmentally friendly, maintenance-free lead-acid battery.
  • Single-column mast with wide view for operator.
  • Incorporates programmable control technology with fault diagnostic function.
  • Emergency brake function improves the safety operation.
  • With low-voltage protection function.
  • With fault diagnosis and maintenance functions.
  • A machine with many other functions, it can accommodate a variety of hydraulic lifting attachments.
For further information regarding any model in RUYI's range, please
contact:
Mr. Chu Jiang
Vice President
NINGBO RUYI JOINT STOCK CO., LTD.
Tel: +86-571-87153626, 87153634
Fax: + 86-571-87153628, 87153638
E-mail: sales@xilin.com/ ruyi@xilin.com
Website : www.xilin.com
Click here to view Ruyi's Shopfront
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
