PowerBatt - unique easy way to prolong the life of batteries
- 23 Apr 2015 ( #715 )
Originally developed for use in the Czechoslovak Army and currently Approved by NATO, PowerBatt is a unique and easy way to prolong lead-acid batteries´ life, increase their operatibility and bring savings from batteries management.
By simply pouring PowerBatt into electrolyte of a battery, PowerBatt:
  • Eliminates coarse-grained sulphates and crashes them into fine-powdered form
  • Increases porosity and strength of active mass on the plate
  • Decreases grid corrosion and helps the active mass to connect with the grid
  • Creates fine films around crystals of active mass what leads to larger effective area and higher capacity of the positive electrode
  • Increases the mechanical strength and electrical conductivity of the active mass and ultimately improves the performance of battery
By applying PowerBatt, it is proven to prolong a battery life up to 100 percent
Seeing is Believing. Try it Now!
For more information, go to www.powerbatt.info or contact us directly send an email
50% Discount trial before 30th June 2015
See endorsements for TVH, Battery Gurus and Continental
MATERIALS HANDLING ATTACHMENTS
Apr 2025
ARTIFICAL INTELLIGENCE
May 2025
There are some clear themes emerging from LogiMAT 2025. Chief among these are electrification and automation, with AGVs proving one of the most-exhibited product types at the show... Continue reading
Apr 2025
May 2025
Apr 2025
May 2025
