PosiCharge Battery Rx – Extending The Life of Your Batteries
- 21 May 2015 ( #719 )
5 min read
PosiCharge - More Power To You
UNDERSTANDING BATTERY HEALTH
With more than 18,000 charging stations delivered, PosiCharge systems have a proven track record of prolonging battery life. We have many examples of customer batteries that have been in service for more than five years in a fast charge application, as well as heavy-duty auto manufacturing customers whose fast-charged batteries have retained 92% of their rated capacity after three hardworking years.
Being a leader in fast charging, as well as power cycling and test equipment, we understand what is important to maintain the health of your batteries and extend their life. Some of these include: weekly EQ, weekly watering, minimal over-discharge, preventing overheating, and a proper charging algorithm.
Battery Rx
Battery Rx
Our proprietary system, Battery Rx, combines accurate data, smart battery management, cellular wireless communication, and user-friendly software to give you the latest in battery management, battery care and warranty compliance tracking. Battery Rx monitors, records, and reports on the key parameters used to diagnose the health of your battery. Battery Rx can communicate wirelessly to report warranty deviations and to send automatic alerts. The data storage can accommodate eight years of battery and charge data, which is much more than the life expectancy of your battery.
BATTERY Rx IS SIMPLE
The Advanced Battery Monitor is easily installed onto the battery and is used to uniquely identify the battery. Battery Rx lives with the battery for the rest of its life while tracking and storing battery health and charge data. The system communicates with the chargers and transforms your facility into a "smart fleet" operation. Cellular communication delivers actionable data in real time without costly infrastructure. You won't have to worry about continuously checking your battery parameters and health because Battery Rx does it for you 24 hours a day, 7 days a week.
Key Features of Battery Rx
Charge Control
Specific Battery Parameters
Closed Loop Control
EQ Control
Sensors
Current
Voltage
Mid-Pack
Electrolyte Temperature
Water Level
Event Logs
Charge Logs
Performance Logs
History/Warranty Log
Fault Log
Email Alerts
Low State of Charge
Missed EQ
Low Water
High Battery Temperature
Pack Imbalance
WEB-BASED PORTAL BRINGS THE INFORMATION TO YOU
PosiNET® is the most comprehensive tool for monitoring charging and battery health for fleet operations management.
PosiNet - Daily Charge Report
Built on a unique system architecture that uses a combination of cellular technology and web hosting, PosiNET automatically captures and analyzes operational data. This process creates actionable fleet usage and warranty compliance reports, thereby empowering operations professionals to manage their fleets effortlessly. PosiNET has an intuitive user interface that provides the right data, in the right format, and at the right time to enable true fleet management.
PosiNet - Battery SOC vs Break Time Report
PosiNet provides you with all the data needed to determine performance issues. It can present that information within 22 different reports including a weekly operations summary. The system also allows you to remotely control the charging process and provides over-the-air updates for the latest software features.
PosiNet - Operations Status Report
Battery Rx with PosiNet Web Services is AUTOMATIC and ACTIONABLE. There are no manual downloads. There is no need to change infrastructure. And the alerts and reports come right to your desk. Our systems will help you monitor and maintain battery health so you can defend warranty claims or ultimately, buy less batteries. Learn more at PosiCharge.com.
PosiNet - Warranty Report by Ahs
IS YOUR CHARGING SOLUTION THE RIGHT SIZE FOR OPTIMAL BATTERY HEALTH?
Our PosiCharge team can provide you with a free assessment using our proprietary E-meter tool. The E-meter records real-time to provide exact energy usage and available charge time to calculate the optimal charging solution. It's compact and fits right into the battery compartment and installs in minutes. The plug-n-play feature allows no disruptions to an existing operation and the data is transmitted through a cellular connection. We'll deliver a usage and system configuration report to properly size your unique charging solution. PosiCharge has a proven track record using this method, which will promote longer life for your batteries and in the long-run, save you money!
ARE YOU STILL USING LP? HOW MUCH FUEL ARE YOU THROWING AWAY?
We can provide you with a free assessment using our proprietary LP-meter tool. It captures real-time activity and fuel consumption to calculate a Return on Investment by switching from LP to electric. It's compact and easy to install in minutes - mounted to the overhead guard or LP Tank. Data is collected through a cellular connection for a week. Our PosiCharge team will deliver a report with usage information, cost savings analysis, and a recommendation for a right-sized charging solution.
Learn more at PosiCharge.com or call for a free assessment at 1.866.POSICHA (1.866.767.4242)
ABOUT POSICHARGE
Committed to continually improving, enhancing and releasing new intelligent energy management products for the material handling market, PosiCharge fast chargers set the standard for rapid charge systems. AeroVironment, PosiCharge's parent company, has developed breakthrough power electronics and battery management technologies for over 30 years. PosiCharge systems - the most advanced line of fast chargers available today, is a product of this rich heritage. As the developer of the premier fast charge system for electric cars, PosiCharge was able to effectively reduce charge times by a factor of 12. When applied to the world of material handling, this revolutionary innovation saved the material handling industry millions of dollars annually by eliminating battery-changing operations. Moreover, PosiCharge makes the conversion from internal combustion to electric vehicles more affordable by reducing battery costs for operations executives and managers. By reducing the number of cost-prohibitive batteries and optimizing assets, AeroVironment and PosiCharge fast chargers continue to play a critical role in improving the way industries and individuals minimize impact on the environment. Entire fleets of industrial electric vehicles that move, store and make product for Fortune 500 companies are powered by PosiCharge, every single day.
AeroVironment PosiCharge
t: 1-866-767-4242
e: send an email
w: www.posicharge.com
PosiCharge Fast Charge Line of Products
MATERIALS HANDLING ATTACHMENTS
Apr 2025
ARTIFICAL INTELLIGENCE
May 2025
There are some clear themes emerging from LogiMAT 2025. Chief among these are electrification and automation, with AGVs proving one of the most-exhibited product types at the show... Continue reading
Apr 2025
May 2025
May 20-21, 2025 - Frankfurt, Germany
July 2-4, 2025 - Bangkok, Thailand
September 15-17, 2025 - Long Beach, CA, United States
Terre Haute, IN, United States
St. Louis, MO, United States
Johnston, IA, United States
Standardised crash test dummies appeared in the 1960s. Over time, crash test dummies better replicate the size and anatomy of a human and all its parts, as well as the range of motion of limbs and joints. Today's versions contain sensors to record damage and respond as humans do.
Apr 2025
May 2025
