Novice workers with little experience and minimum skills can easily set the stage for disaster. With this situation, the stakes are high, especially when working with heavy machinery such as forklift trucks. Inexperienced operators may not be accustomed to your forklift, (equipment), so, this may increase the odds for product and pallet damage, resulting in unnecessary costs. Thorough training would be the ideal solution, but in the real world, it's simply not always possible to get temporary employees up to speed in time. The driver may might not be aware that the forks protrude through the rear side of the pallet. It can lead to costly product and pallet damage and injury to other personnel. |
| | | Damage caused because the lift truck forks protrude at the rear of the forklift. |
Relax, a simple solution is available!If your application requires
two-way pallet handling or
differing load lengths, and you have experienced damages you can now relax, as there is a simple solution. Extendable hydraulic forks allow the operator to adjust the tines to the correct length at the touch of a lever and without getting off the truck. Even though your permanent employees may know all the tricks to handling various pallet sizes safely and efficiently, this solution can help them as well. Oversized forks often cause product damage and hinder movement. Adjustable forks solve these issues.
Avoid the costs of product and pallet damageExtendable lift truck forks,
manual extendable and/or hydraulic forks, can help avoid the problem shown here. Extendable forks add value to forklift truck in the form of added versatility which results in cost-savings. And, in the case of a less experienced lift truck driver, these innovative forks can help you avoid the unnecessary costs resulting from damage or worse yet, injuries! Telescopic forks ensure the correct fork length is always available.
Meijer Handling Solutions
P: +31 (0) 518 49 29 29
E: send an email
W: www.meijer-handling-solutions.comAbout Meijer
Meijer Handling Solutions aims to add value to our customers' and end-users' logistical supply chains. We are the world's market leader in hydraulic lift truck forks, known as KOOI-REACHFORKS®. Also, we are known for our palletless handling attachments such as the patented ROLLERFORKS® and our unique PushPull systems.
