Cascade Europe Introduces the R-Series line of Fork Positioners for Class 4 Trucks.
Thursday, 5 Nov 2009
Cascade's R-Series Fork Positioners are designed for ISO class 4 trucks with a capacity range of 6000kg - 8000 kg. Ideal for heavy lifting applications the R-Series Fork Positioners use pin-mounted forks or standard ISO Class 4 forks.
Models:
Non-Sideshifting with forks
Non-Sideshifting with fork carriers
The new design includes:
Separate Sideshifter uses nylon upper bearings and lower rollers
Excellent operator visibility
No-weld installation
Pre-Drilled to accept load backrest
Fork Carriers accept forks 150 mm or 200 mm in width
Cylinders located inside the top frame to resist corrosion caused from debris
Removable top frame cover for easy access for servicing cylinders
