Choosing a forklift preventative maintenance program
Peter Greenthal -
Your Focus
- 9 Jun 2011 ( #517 )
Peter Greenthal
Peter Greenthal
Preventative maintenance is often overlooked, but according to Peter Greenthal, it can save time and money in the long run.
When buying either a new or used forklift, the secret to a good return on your investment is a quality preventative maintenance program. There are seven factors that should be included in any program you select. Keep in mind that a preventative maintenance program is not meant to eliminate the need for maintenance. Instead, it should reduce the amount of productive time lost due to a malfunctioning lift truck.
1. Any good maintenance program should be completed on a regular schedule. Depending on how actively you use your forklift, maintenance should be done on a set schedule. So any provider you choose to go with should be able to keep track of your maintenance schedule and inform you when it needs to be performed next. Most forklift manufacturers require their products to have a preventative maintenance process completed every 150 to 200 hours of operation.
2. Look for a service provider that is capable of maintaining a history of your forklift maintenance performed, as well as repairs completed. This is critical for many reasons. It allows you to understand how much you are spending on this process as well as to identify recurring issues. It will also allow your provider to customise your maintenance program to fit your use and operation. So if you have a dirty operation, the provider will know to always come prepared with new filters because the old ones are probably going to be dirty.
3. Any reasonable preventative maintenance program should have a comprehensive and thorough inspection and function-testing checklist. This is the list of specific items that the technician will inspect and perform on your equipment to make sure it is in the best running condition possible. You should ask to review this check list when interviewing a service provider and see if it covers the items specific to your equipment and operating environment. Once you and your provider have agreed the checklist is right for your equipment, the service provider should provide a completed copy of the checklist each time your preventative maintenance program is completed.
4. One of the most simple but probably least understood processes in a preventative maintenance program is the cleaning of your forklift. The number one cause of forklift downtime is dirt and debris. A preventative maintenance program is only as good as the cleaning your forklift receives. Make sure that your provider is taking the time to clean your forklift thoroughly including, but not limited to, blowing out the radiator with compressed air, wiping down the hydraulic cylinders, and replacing dirty filters with clean ones.
5. Upon completing a thorough cleaning of your forklift, your service provider should lubricate your forklift in accordance with the manufacturer's instructions. This should be done with quality lubricants and in adequate amounts to ensure moving parts will do so with ease and reduce wear.
6. Use only quality replacement parts on your lift truck. They should meet all of the forklift manufacturer's specifications.
7. Finally, a good preventative maintenance program for your forklift should be at a fair price. Typically, to do this job properly, a mechanic should need one to one and a half hours to get everything done correctly. So the cost should be reflective of the time spent.
Peter Greenthal is president of Boman Forklift and Hyundai Forklift of Southern California.
Also Read:
Fork Talk - Winners announced for student competition
2 minute read
Fork Talk - Winners announced for student competition Your Focus - 9 Jun 2011 (#517) Fourteen student teams from the US and Canada have won the 2011 AEM Construction Challenge that took place on 25-28 May at the University of Tennessee in Knoxville. The Association...
Rob Vetter
3 minute read
To Lift or Not to Lift Your Focus - 19 May 2011 (#514) When should forklifts be used to lift people? According to Rob Vetter, never!
At the time of publication, the US administration was pushing ahead with its new tariffs which have had a seismic impact on the world economy and markets. Of most concern to many is the escalating tariff war between the US and China, with the European Union and many other countries also considering, or already having imposed, reciprocal tariffs. How this will play out for the materials handling sector, and the world economy at large, simply cannot be fully understood at this stage... Continue reading
May 20-22, 2025 - Dubai, United Arab Emirates
September 15-17, 2025 - Long Beach, CA, United States
October 23-25, 2025 - Hangzhou, China
MATERIALS HANDLING ATTACHMENTS
Apr 2025
ARTIFICAL INTELLIGENCE
May 2025
