CAT P6000 - AT13F01090 - Code E24
Hello Code E24 - Got to this unit after backyard mechanics FUBAR it
Wiring a mess but all continuity good
Had a E23 code bad ECU- Changed ECU - Now Code E24 -Tried to relearn throttle pot - 2 sec 10 sec 2 sec - Still Code E24
Looking for some more detailed service information
Suspect relay or bad Throttle Pot??
prenticelift at gmail dot com
  • Posted 25 Jul 2015 06:07
  • Discussion started by Prentice
what are the procedures for the relearn or can you send me a link to where you found them? i've got 2 CAT lifts down with this same issue.
  • Posted 25 Feb 2025 06:04
  • Reply by Tank_420
How do you do the throttle pedal learn
  • Posted 7 Jun 2022 01:33
  • Reply by Vernon_Jackson
Vernon
Need software or manual to reset pod, or explain the steps
  • Posted 22 Nov 2019 04:58
  • Reply by Norman_Arter
  • Tennessee, United States
Norman Arter
sbhbrett,
you can try disconnecting the battery for 15 mins and see if that resets it but i doubt it will, that info is generally hardcoded into the programming.
Usually that is reset through the software and a relearn command is given using the software.
  • Posted 1 Jun 2016 21:23
  • Modified 1 Jun 2016 21:23 by poster
  • Reply by swoop223
IS there a way to do the Air Idle Volume learn manually or do need to have the software?
  • Posted 1 Jun 2016 00:17
  • Reply by sbhbrett
Ok got it - found Throttle pot out of adjustment - it was centered - moved to the old mark's (full foward)- performed the throttle learn tests again - Erased codes good to go - Thanks for your help guys
  • Posted 29 Jul 2015 03:31
  • Reply by Prentice
one of the most common problems with the throttle body code E23 or E24 is broken wires at the plug harness.
There could also be a throttle plate linkage hanging or damaged gears in the motor causing it to hang.
Also if the battery is disconnected, or the throttle body disconnected/replaced or the accelerator sensor disconnected/replaced you must perform:
- accelerator released position learn
- throttle valve closed position learn
- idle air volume learn (fast TAS normal)
Failure to perform these learns may cause these codes to set.
  • Posted 25 Jul 2015 13:34
  • Modified 25 Jul 2015 13:36 by poster
  • Reply by swoop223
The etc relay,3rd down can be checked by turning key to run position, if it is good you will hear the stepper motor in the electronic throttle control cycle. If it is bad take the fuel pump relay and swap it, this is assuming the truck is not dual fuel or gas powered. The accelerator unit is two different pots check 5 volt reference and ground for each pot, if you have access to a quality scan tool, ie snap on Solus Pro, you can monitor apps sensor voltage, jump 5 volt refernce to signal for each sensor, and scanner should display 5 volts. Jump ground to signal and scanner should indicate 0 volts, this is to test circuit integrity, if good replace accelerator pedal position sensor.
  • Posted 25 Jul 2015 09:56
  • Reply by jeremy_s
edition #1224 - 3 April 2025
In this week’s Forkliftaction News we look at two topics coming out of LogiMAT 2025 held in Stuttgart in March. The first was the large increase in exhibitors coming from China who are making it clear they have their sights set on markets outside of China (see story). The second is a closer look at what was the main theme of the trade show - the growing rise in automation, how it is changing the sector and how enthusiastically it is being embraced by younger generations... Continue reading
Berry Mansfield Berry Mansfield
President, Mitsubishi Logisnext Americas
Chief executive officer, Messe Stuttgart India
President, Logistics UK
vice president, warehouse systems , Fleet Team
May 01, 2025 - Blair Athol, South Australia, Australia
May 27-29, 2025 - Riyadh, Saudi Arabia
September 9-11, 2025 - Birmingham, United Kingdom
